  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Hehe, well you should have rethought that pic that you took last time:p
See'ya:burnout:
Is she STILL pissed off about that ??
I can post it up so she can delete it. lol
Cheers
Ken
Oh how's this - pwptf & ken - what an occasion!
Ken - tech time:D
Been thinking about a 2wd/4wd switch. What if I connected a switch to the fuse under the dash that controls the 4wd & abs - flicking th switch is just like pulling the fuse - no more 4wd - great for circle work, etc
Ken - tech time:D
yep should work . I got the one that plugs into the G Sensor under the console.
Circle work is good in 4wd though.Makes you damn near pass out with the G force.
Cheers
Ken
    • If by axles you mean driveshafts, they're supposed to have play in them. They are not hard to recondition, it's just pulling apart the cv's, cleaning them and regreasing, fit new boots. I've only rebuilt one set and there was fk-all wear in them, still running just fine 8 years later.
    • Note, the aluminium bit that screws in the end that you have to remove to dismantle the rack is single use as it's punch-marked, it will strip when you unscrew it, and then you have to flatten the notch in the steel rack body, screw in a new aluminium end when rebuilding, then punch-mark it again once assembled. it is also 'somewhat tricky' to refit the rack>steering wheel linkage gear as it needs to be set to the right preloads etc. A rebuild is probably something that's better just given to a steering shop for a couple of hundred, unless you're mad-keen to do it yourself.
    • Do you have the workshop Manuel? Sorry that's a Spanish waiter...I mean, manual? Some relevant pages>
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
