  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Niz - thanks for giving me the opportunity to get naomi to socialise with you all - helps give me more time to play cars the more she gets involved:D
No worries Micko , I'm sure we can keep your wife amused while you play cars....:D
Cheers
Ken
no probs Micko - glad u both had a good time :) hope me and my friends didnt scare her :D
Ken my last job was 19K and i was miserable in that the 35K makes a job so much more bearable - its not sooo mucht he job but the environment - hehe but revenge is mine - my supervisor was told he had to go down from a level 6 to a level 2 - the same level as me hehe - actually as of june 30 they pretty much have all new staff in that place - that will probably count me as gone as well
Yep Ken, got the mines ecu in. Was using the stocker before that though.
Should have the car on the dyno Wed night if steve can fit me in so we can see what the a/f ratio is like.
Car goes pretty good now methinks. Worth having the aftermarket dial in the car now;)
In that case , theres the problem. I would say the fuel ratio will be a bit rich as the japs like a lot of fuel and timing.
Cheers
Ken
I owned 2 businesses ( wrecking and Driver Training )
Made some SERIOUS money but the satisfaction wasn't there after a while.
Am working in a mates shop on the tools earning less than you but am happy , no stress, no employees , no aggro.
Life is good atm and I enjoy my time talking about cars again with people who like them for what they are and not a source of making money out of.
Cheers
Ken
did the guy withthe black skyline that liz is interested in end up ringing u today ken?
yep looked at it when he finally came to work at 5pm.
I won't steal liz's glory except to say she prolly won't be looking much any more.
Cheers
Ken
Cheers
Ken
good for u ken :D
brave wish i could be like that but atm i need the money and not really sure if i want to do anything else maybe if work was more demanding of my time and not so boring i would feel different.
but you've made money ken :D if it wasnt for that u wouldnt have the lifestyle and the ability to downgrade the job.
I havent made any money really - havent been able to acquire investments but when i get older i'll probably be able to do the same but for now its boring old work for me.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
