  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
buffy not on tonight
yeah neons are legal and can be on while driving as long as u can't see the tube from look at the car from any angle
there not allowed to be hooked into the stereo so they flash etc
Neons are legal
Think we had better call the rice police
*Maaaaaccckkkaaaa , Gradeeeeeennnnnnkkkkkoo *
get the uniforms on boys , theres some serious rice catching to be done. :D
Cheers
Ken
Really? thats interesting looks like ill have 2 hook some up!
haha just kidding:p
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
