  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
mess up the desk - bring up an excel spreadsheet everytime someone walks past ponder hard at it when they go away alt-tab and you've got the forums or your email box - emailing can also make u look busy!!
Yeah, well my boss sita and listens to me. If I am typing lots she knows I am not working. Silly cow yesterday had not done a single work order sheet (takes 2 minutes) and I had done 4 TA sheets (takes ages, about 10 work orders to each page) and she told me off for answering 1 e-mail!
Old bat who is just jealous cuz she doesn't wanna grow old and is and I am only 18. If anyone heres of a job can they let me know, I have 4 months left on my contract but I wanna find something before it ends and I am un-employed. Thought I might start looking now.
hehe yep only person that catches me is Mr very sneaky - i can never here him coming up behind me - i should ask for my desk to be moved because im facing the wrong way for good feng shui :(
Well, I have it cut just past my shoulders and shaped, never cut it short. I don't like that.
I have Archibus up, put e-mail or forums over top, someone walks past and I minimize it and archibus is still there so it looks like I never went off it. We are allowed on there, she is just a old bat.
contract sucks bayley!! u have four months i have a month and a half - agh i spend all my day typing they know i aint doing shit but they dont give me anything to do so what do they expect. I used to email a bit in New Town Tho - but it was funny cos one of the ex employees used to send me dirty emails so one of the old guys would sit there and see me with a smirk on my face and come over to have a read!
Ashley (R31 Nismoid) sent me some real funny ones yesterday but I had to delete them all cuz they had titles like Stiffweenie and they can chack up. If they found that on my e-mail I would be instantly sacked! Will have to give him my home e-mail so he can send them again.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
