  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
Joe have some water..
Remeber ratio
4:1
4 bottles of water to 1 glass of beer :P
Christ !! is that right.
Looks like they had better build a bigger dam with the amount of booze I consume.
Cheers
Ken
Originally posted by Micko
Ken - you walked in just at the right time...
What is the diff between resistor & non-resistor plugs?
Steve told me not to get the resistor ones because they wont be as good. Most people seem to be using resistor plugs though:confused:
I dont think your on the right track there...
Plugs are all resistive....some low and some high??
Macka you ain't see me drink cos you only go to places where I have to drive home.
If I was staying or getting a lift home , well then you would see some......
Micko , unsure about the diff but think you need resistor plugs with electronic ignition.
Doesn't Hendo recommend BCPR7es-11 or something like that
Cheers
Ken
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
