  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
How does it work then - i was told to gap them to 0.7 which quite small.
Does this mean i will get a hotter, more intense spark?
What is the normal school of thought when you increase boost?
Gap to .7 or .8 mm cos most of the modern plugs gap to 1.1mm hence the 11 on the end of the plug number.
The large gap is what gives a bigger stronger spark because it makes the coil build up a larger voltage to fire the spark across the gap.
The trouble is with turbo engines running larger than stock boost will blow the spark out while it jumps the gap ( simplistic terminology ) hence the need for a smaller gap , which then gives a weaker spark and is the reason why splitfire or cdi type ignitors are reqd on BIG boost engines.
Got it ?
Cheers
Ken
I think he was annoyed with how you addressed his indescretions...a little more tact would have been appropriate
Nah stuff it, just walk over and deck him. Hehehe
Tell us first so we can set up seats and get the beer and chips out.:P
Cheers
Ken
Got it ?
Cheers
Ken
Cylinder heat causes injector fuel to ignite before the spark flashes over :P
Thanks Ken - I had heard about the spark being 'blown' out.
Good work macka - blamed the wrong bloke...you are a tool (7/16 combination ring spanner if I recall):bahaha:
Maybe u should read more carefully,
I asked if he was the guy who hoons around my street picking up some girl he said yes
Im not going to change my driving habits because thats the way i drive and thats not going to change...
I accused no one
This plug talk is doing my head in...
So if I reduce the gap I should use a hotter plug to keep the actual spark the same?
Why do people go colder in most higher boost applications?
Colder plug means it will take heat , boost and thrashing better without melting or dropping the electrode off.
A hotter plug is used in colder conditions to aid starting or is used on a worn , oil consuming engine which would foul a colder plug.
Phucked with your head enough ??
Cheers
Ken
Anyway - who cares...
ZACHARY !!
I sure as shit don't sherlock.
Though if that spanker next door with the new loud exhaust on his rex goes belting down the street one more time....
Cheers
Ken
Right - almost done...
What this is telling me is that I should have gone to an NGK 8 (or stayed with a 7).
Micko , what plug exactly did Steve recommend.
I have checked my reference and Hendo told me to use
BCPR7ES -11 and gap them to .8mm
Cheers
Ken
PS I have and they work fine.
    • Got my 34 gtt tuned last week. Cat made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now.  IMG_7261.mov
    • Hi everyone, I'm wondering if anyone in Melbourne (preferably West) has a non-S2 R34 front bar. If it's already off the car, even better!  Nothing too weird, I just need to get a cut-out of the hole that the front indicators clip into 🤣 (image attached for reference)   I've got a front bar from JSAI Aero, but those holes need to be cut myself, and I want to get it right so the indicators will clip securely. And my OEM bumper is a S2, so I have no reference. So looking for a member who might be able to spare me a few minutes to make a cardboard cut-out using your front bar.
    • Not sure what you mean by electronic speedo drive.  Speedo reads fine up to 180 yes.
    • For anyone interested, this is my old graph from 2021, but I've plotted the previous setup curve onto it with a black pen. old setup was: pon cams, oem itbs and plenum, HPI manifold, hks 2835 pro S .87ar rear, Turbosmart actuator, 3" turbo back no res. or cat., greddy spec M fmic, nismo 740cc inj, walbro in tank 460, splitfires, 4" intake pipe, Apexi pod, e85, eboost2, power Fc. I love that the new setup has much larger turbo spec with the HTA3076 1.01ar Ts rear, and literally everything is bigger, but far higher quality and result is it's FAR more responsive in paper.
