  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
How does it work then - i was told to gap them to 0.7 which quite small.
Does this mean i will get a hotter, more intense spark?
What is the normal school of thought when you increase boost?
Gap to .7 or .8 mm cos most of the modern plugs gap to 1.1mm hence the 11 on the end of the plug number.
The large gap is what gives a bigger stronger spark because it makes the coil build up a larger voltage to fire the spark across the gap.
The trouble is with turbo engines running larger than stock boost will blow the spark out while it jumps the gap ( simplistic terminology ) hence the need for a smaller gap , which then gives a weaker spark and is the reason why splitfire or cdi type ignitors are reqd on BIG boost engines.
Got it ?
Cheers
Ken
I think he was annoyed with how you addressed his indescretions...a little more tact would have been appropriate
Nah stuff it, just walk over and deck him. Hehehe
Tell us first so we can set up seats and get the beer and chips out.:P
Cheers
Ken
Got it ?
Cheers
Ken
Cylinder heat causes injector fuel to ignite before the spark flashes over :P
Thanks Ken - I had heard about the spark being 'blown' out.
Good work macka - blamed the wrong bloke...you are a tool (7/16 combination ring spanner if I recall):bahaha:
Maybe u should read more carefully,
I asked if he was the guy who hoons around my street picking up some girl he said yes
Im not going to change my driving habits because thats the way i drive and thats not going to change...
I accused no one
This plug talk is doing my head in...
So if I reduce the gap I should use a hotter plug to keep the actual spark the same?
Why do people go colder in most higher boost applications?
Colder plug means it will take heat , boost and thrashing better without melting or dropping the electrode off.
A hotter plug is used in colder conditions to aid starting or is used on a worn , oil consuming engine which would foul a colder plug.
Phucked with your head enough ??
Cheers
Ken
Anyway - who cares...
ZACHARY !!
I sure as shit don't sherlock.
Though if that spanker next door with the new loud exhaust on his rex goes belting down the street one more time....
Cheers
Ken
Right - almost done...
What this is telling me is that I should have gone to an NGK 8 (or stayed with a 7).
Micko , what plug exactly did Steve recommend.
I have checked my reference and Hendo told me to use
BCPR7ES -11 and gap them to .8mm
Cheers
Ken
PS I have and they work fine.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
