yes it was sad , they all asked how there times were and I said that Stewie in a stock std road GTR with crap tyres ( who was instructing today btw ) posted a time about 2 secs quicker than the best rex they had there.
Hate to burst the bubble but they ain't that quick and under steer too much:D
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Romour has it that if the weather isn't too bad tomorrow there might be a cruise happening.
If so, are you going to be able to make it?
btw - I put some BCPR7's in today. Car feels stronger, just gotta be careful not to get carried away with the higher rev limit...
No worries Adam....
Cheers
Ken
not much bud - just got home from watching the new matrix movie - i loved it.. everyone else hated it.. wierd... i guess it wasn't a holiwood formula movie so it didn't get props from many...
u guys have that dinner tonight?
somehow i don't think the weather is going to get any better bud...
so did you change the exhaust timing with the gear? think it makes much diff? it's hard for me to tell cause i did the elec boost controller, dump and pulley all at the same time..
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
