  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i HAVE to do something with my tyres - its no fun when your car bounces all over the road and the steering wheel becomes unhandable at 120km's *sigh* need to borrow some tyres for next Saturday!!
mmmmm carbon fibre. So much to do so little money haha im battling to afford new set of tyres and i have to do something about my brakes too - it aint pulling up as quick as it used too - m pads are in desperate need of replacement!
yeah but i need some "loaners" for next weekend - they are really bad to drive on - just ask the people behind me that saw me skipping all ove rthe road while trying to keep up today.
When i do change them over for good I'll get a good quality set - seen what shit tyres can do for your car!
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
