  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
that pic was taken early morning back in feb of when I first had the cooler put in :) Looking at my car sat next to niz's made me see how crap the stock car looks :( I have a set of side skirts and rear pods, which I should get on in the next few weeks, then I might have a look around at a new front bar. I'm not sure about lowering the car though as I have a high kerb to get over on my driveway and the last thing I want to do is scrape a front bar on it. Plus pauls got some 18x9 enkei rims (only 2 though :D ) for my rear then I can wack some 255 rubber on em :)
thank u aidwin - yeah im pretty happy with the way my car looks - apart from my back wing is cracked and my dad did a bodgy job trying to fix it haha. All it needs is so go fast bits haha
yes i did thanks Kyles - can i get back to u a bit later - paul says its alright if i still go down with him so yeah just give me a couple of days to get my head straight and i'll figure out what is best for me to do :) Thank u again tho - thats most generous of u & Troy :D
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
