  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
ok I am editing that post so it doesn't sound like that now!!!
Should I email Jeff and let him know thanks but no thanks? You know - to be polite?
I wouldn't worry too much about it.
He gets lots of people in looking at his cars who don't buy.
It's all part of running a caryard.
Cheers
Ken
But I feel bad cause he was really nice (not just cause hes a dealer) but he was honest as well
Well email him then. I suppose you could word it nicely but just don't mention I helped your decision to buy elsewhere:D
My R is in the CRed shop atm and I don't want him sabotaging it. j/k
Cheers
ken
hey ken
haha who was it that took mums call at MC's? She enrolled me in payed for it today and the guy asks what kinda car i drove so she goes Nissan Skyline and he asked if it was a GTR and she didnt know and said hmmm dont know i think so - its got the plates Nizmo. and he goes "oh ive seen that car - hell she's a wild driver - shot past me one day and nobody shoots past me" :) funny i dont remember him taking me on tho!
Need to make sure that Micko has you lot organised for Sat.
Remember Niz , it's a 7.45 there .
Make sure the car has at least 1/4 to 1/2 tank fuel and the tyres are pumped up to about 38-40 psi.
Cheers
ken
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
