i dont like maccas - it just sits in ya stomach - apparently if u eat maccas and they cut u open a year later the forsenics can still tell u had maccas back then cos of all the preservatives haha
Like a whopper - but i take the meat out usually to stop that sitting in my stomach as well - hate the bloated feeling!!
I just had a really small piece of chicken parmigiana and steamed veges for lunch :)
I need to learn how to control my car in the wet anyway - i have a phobia about driving in the wet i need to overcome - too many close calls in wet in the ZX and most of my driving lessons were done in the wet and they werent happy memories!!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Women's Advice to Men
The reason why our bras don't always match our underwear is
because WE actually change our underwear.
The next time you and your buddies joke about armed women in
combat, take a poll to see which of you successfully aim at
the toilet rim.
If we're watching football with you--it's not bonding--it's the
butts.
If the truth hurts, ask us those ego-sensitive questions on your
payday.
The next time you joke about female drivers, research the number of accidents caused by rubber-necking mini-skirts.
If only women gossip, how do you and your friends keep track of "who's easy"?
Stop telling us most male strippers are gay: we don't care.
Your contributions to your child should go above and beyond that y chromosome you unselfishly sacrificed.
Your balding is a good thing--it subsidizes our hair care expenses.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
