  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
Ken - is there another course running??
Liz , there are courses up there all the time but depends on how many people.
Some are only $60 but lots of people.
This was $185 but only 5 people and lots of track time including instructor with you in the car.
Cheers
Ken
ken - I think I need to do something - cause I shouldn't be driving hey... I am soo scared
Scared of what?
It's an invincible Skyline and hasn't yours got an airbag?
I had two in mine but the Mother in law and wife don't come along any more..
Cheers
Ken
Of crashing. Yeah it has an airbag - but when I hear a crash on the TV - I am pyshically sick, if I come up a bit quick to another car all I see is the accident. If I am driving and its stressful - like heavy rain or something I can;t breath properly. I never used to be like this - i was confident before
Hey aiden... nah I think I might have broken something :D I can still move all my toes but it still hurts a fair bit, even when I took a pandol forte lastight... just wait and see I guess, give it a couple of days. My wife freaks out as soon as I plant my foot and the turbo spools, so I drive like a nanna when she's in the car :)
Originally posted by Nizmo
i think life is about enjoying it :) i think we should try and keep ourselves healthy but cant deny ourselves of lifes little pleasures.
Yes I am Ken :) someones gotta keep u boys in line :)
Hey Liz do u ever have girls rearrange your clothing in the ladies loos - i dont know whther its just because im an untidy dresser or what but hell i keep getting these chicks trying to straightenup my clothing and suggesting the type of bra i should wear with a top :D
Oh all saw a girl i used to work with - she was sooo happy to see me - she was threatening to bash my face in 3 years ago!!
Don't get that in the guys toilets.
Maybe I should start frequenting the Ladies ones instead.:)
Cheers
Ken
Nah my wife refuses to drive my car... I wouldnt let her anyway :D she'd crash it :) Sneeza just drive like a granny in the wet... I do, I do the speed limit, I just dont floor it at all just let it rev gently to 3000rpm and then change gears. If you drive sensibly in the wet the turbo wont spool up and you wont have any issues :)
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
