  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
Of crashing. Yeah it has an airbag - but when I hear a crash on the TV - I am pyshically sick, if I come up a bit quick to another car all I see is the accident. If I am driving and its stressful - like heavy rain or something I can;t breath properly. I never used to be like this - i was confident before
Liz I have been in more accidents than most ( usually as a navigator ) but found that by having confidence in your safety equipment and your self , the fear subsides fairly quick.
With the amount of times I have been in a roll ( bout 25 ) I worked out I am not destined to die in a motor car.
Cheers
Ken
Originally posted by SHUTO-BOY
i think we should organize some sorta wet skid pad day
-my friend fully crashed his s15 the other day because he lost traction and panicked,did the wrong thing and braked..and flipped his car
Unfortunately , there is no one in Perth who has a skidpan.
When it rains at the MC track , it's great fun though.
Originally posted by caminperth
lol @ ken.. after 25 rolls (separate occasions?!) then i'd say you have a correct hypothesis.. :D
Nah , 1 rotation is a roll. Was in a Triumph herald ( shaddup ) rally car that went over 31/2 times and caught fire.
Wrote off my rx7 rally car at a Sth Australia rallysprint with a 31/2 ( including 2 in the air ) .
Targa was 1 or so in 2001.
2 with my dad in a Datsun 1600 rally car
The list goes on...
Cheers
Ken
wow got some crazy friends hope the he comes out of his coma shortly.
hehe find a fwy liz n give it ago - only took me three days to find the accelarator but once u hit boost hehe you'll never drive like a grannie again :D
sneeza-just recently,
cam- we just need the water spray piping thingy at the edges of the area- u wanna open a drift school?
Drift school is coming.
We are putting together a proposal to run a drift series at the new MC complex at the airport.
Cheers
Ken
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
