  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
Of crashing. Yeah it has an airbag - but when I hear a crash on the TV - I am pyshically sick, if I come up a bit quick to another car all I see is the accident. If I am driving and its stressful - like heavy rain or something I can;t breath properly. I never used to be like this - i was confident before
Liz I have been in more accidents than most ( usually as a navigator ) but found that by having confidence in your safety equipment and your self , the fear subsides fairly quick.
With the amount of times I have been in a roll ( bout 25 ) I worked out I am not destined to die in a motor car.
Cheers
Ken
Originally posted by SHUTO-BOY
i think we should organize some sorta wet skid pad day
-my friend fully crashed his s15 the other day because he lost traction and panicked,did the wrong thing and braked..and flipped his car
Unfortunately , there is no one in Perth who has a skidpan.
When it rains at the MC track , it's great fun though.
Originally posted by caminperth
lol @ ken.. after 25 rolls (separate occasions?!) then i'd say you have a correct hypothesis.. :D
Nah , 1 rotation is a roll. Was in a Triumph herald ( shaddup ) rally car that went over 31/2 times and caught fire.
Wrote off my rx7 rally car at a Sth Australia rallysprint with a 31/2 ( including 2 in the air ) .
Targa was 1 or so in 2001.
2 with my dad in a Datsun 1600 rally car
The list goes on...
Cheers
Ken
wow got some crazy friends hope the he comes out of his coma shortly.
hehe find a fwy liz n give it ago - only took me three days to find the accelarator but once u hit boost hehe you'll never drive like a grannie again :D
sneeza-just recently,
cam- we just need the water spray piping thingy at the edges of the area- u wanna open a drift school?
Drift school is coming.
We are putting together a proposal to run a drift series at the new MC complex at the airport.
Cheers
Ken
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
