  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I just can't see a manufacturer saying .... Ok lets install some blanking plates through our cars in case the people that would like to purchase them want top install aftermarket switches....
Hmmmm your probably right but the switch just looks so factory its not funny.
never stopped us talking about it before haha
yeah i got blanking plates in my car - but ive been in other skylines and where i have blanking plates they have things - where i have buttons they have a blank spot - all they do is produce the base model then install the switches according to whether its Vspec, Manual, Auto etc :) So where u have a blank spot - on another model it aint blank :D
i'll do the washing but stuff the ironing :D ex always had a bit of trouble getting me up at 7am in the morning to iron his shirt - always greeted back with a "f off if u were dumb enough not to ask me last night it aint going to happen this morning" haha
Originally posted by GTS-t VSPEC
Troy, I was impressed to see you working on Micko's car the other day, never seen you get your hands dirty before:p
pulling pipes off and afm's etc i've done b4 so seeing micko was sort of grieving even though he had this big grin on his face, and the fact i'd have to leave early i did my bit :D
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
