  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe yay kyles now all u have to do is christen it :)
hmmm my cat beats up little dogs - even had our doberan scared when we had her - i want a puppy doberman their soooo cute and their paws an ears are always too big for their body *giggles*
my neighbours dog chases my car - only my car - first my ZX now my Skyline - leaves everyones car alone just picks on mine - im sick of dodging that god damn fluffball if they cant kep it on their premises its their problem next time no more dodging it can just go to puppy heaven - its already destroyed two of my tyres on my ZX!! :) Grrrrr
