  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Evening dudes and dudettes.
pwptpf , we are only competing on Saturday . Hillclimb at 9 am , then straight to the motorkhana with me and the missus driving.
Sunday is free but we are heading off at Lunchtime.
Also I do like the Missus , you can try blackmail but won't work cos I said you all lie.
Top the GTR circle work. Hahahaha , I doubt it.
Gee , niz likes me , I gotta do that more often.
Niz , it's arbOrne , not airbOUrne.
Right , think that's it.
Cheers
Ken
