  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
There are 4 blokes living there.. When they moved into the frount house they had one car. They knew that the shared the car port (holds 2 cars) with me. I live in a studio apartment at the back. Stupid idiots went and bought 3 more cars. They have to park them out the frount of their house. Just because they are idiots doesnt mean i or troy should park down the street. Because if we dont get the car port spot we have to park down the street where we cant see the car.
Well, going to catch up on some of the other threads. By the way if you think you have seen me on here in the last couple of months, it wasn't me. It's just when I logged on tonight it said my last visit was at a time when I didn't even have a computer, so I am a little paranoid. One or two people know my password, or may have saved it when I logged onto their computer, though that was a couple of months ago.
smilies are easy
type : ) without the space.
its possible that someone has your password if they have cookies enabled on there pc.
the pc saves the password and the username
when the username is entered or partially entered it will show up in a drop down menu. click on the user name and it will automatically enter the password.
so thats probably how they used your account.
No, not importing, just keeping on the good side of a friend in the business. I have done a lot of unpaid work for him, in the hope he will give me a job once his regisration comes through. He wanted some info from the talk, but couldn't make it as his yard was open. Wed night was really not a good night for it.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
