  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Gotta confirm pricing & transfer some money out of the mortgage - it's times like this that you're glad about any extra repayments you've made:uh-huh:
Brett's price of $400 to install wasn't too bad really - if we do it ourselves it will almost cost me that much too feed & drink you guys:bahaha:
