  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
bloody oath im going to be sad :) hmmm doughnuts - ive been weighing up my cud de sac thinking - i wonder if the neighbours would mind if i practised my circle work - i decided since they let most of their little shits play on the road they probably would. But if theres a motorkhana coming to the grain silo near me soon i wouldnt mind having a go - besides it aint far away to limp home if need be :)
Bam - this is what he said on the PM..... I can't be arsed going to my work email... means disconnecting from here!
yes they will, i was told from a few people they wiil. the caliplers on a gtr and gtst are both four spot. i send them on friday.
(Quote:)
Sneeza wrote on 02-06-2003 01:59 PM:
This is the person who has bought them
(Quote:)
MR33 wrote on 02-06-2003 09:29 PM:
there sold sorry.
(Quote:)
Sneeza wrote on 02-06-2003 09:15 AM:
Hey
Are you sure these will fit an r33 gtst - some one on the forums told me there is no way they will fit
Originally posted by Sneeza
Ken - I know sorry hahaha I saew my mistake....
can he take me to court of I don't accept them?
Liz , don't get so paranoid.
If it really worries you that much , tell him that there has been a misunderstanding and you will send him $40 which should cover most of the freight cost.
All it has cost him is some time and a bit of inconvenience.
Personally I would tell him to check his info more thoroughly before making statements like he has to you and use it as a lesson to not lie to people.
Would he have paid you back when you found they didn't fit ??
Not likely!!
Cheers
Ken
i hear the word meelup but noone is ansewering my question - meelup is it where i think it is near dunsborough? if yes - hopefully its a warm sept day where i can hit the beach :) lurve meelup!!
Originally posted by Nizmo
lol @ ken - they aint going haha so thats it til Meelup eh? that is near dunsborough right?
Liz he cant take u to court not much of a case specially with a record like his :)
You have lost me , who's not going?
Have Wanners on the 9th August then Meelup near dunsborough.
The next state m/khana is on June 29th but you will need to join a car club and get a CAMS lic
Cheers
Ken
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
