  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
bloody oath im going to be sad :) hmmm doughnuts - ive been weighing up my cud de sac thinking - i wonder if the neighbours would mind if i practised my circle work - i decided since they let most of their little shits play on the road they probably would. But if theres a motorkhana coming to the grain silo near me soon i wouldnt mind having a go - besides it aint far away to limp home if need be :)
Bam - this is what he said on the PM..... I can't be arsed going to my work email... means disconnecting from here!
yes they will, i was told from a few people they wiil. the caliplers on a gtr and gtst are both four spot. i send them on friday.
(Quote:)
Sneeza wrote on 02-06-2003 01:59 PM:
This is the person who has bought them
(Quote:)
MR33 wrote on 02-06-2003 09:29 PM:
there sold sorry.
(Quote:)
Sneeza wrote on 02-06-2003 09:15 AM:
Hey
Are you sure these will fit an r33 gtst - some one on the forums told me there is no way they will fit
Originally posted by Sneeza
Ken - I know sorry hahaha I saew my mistake....
can he take me to court of I don't accept them?
Liz , don't get so paranoid.
If it really worries you that much , tell him that there has been a misunderstanding and you will send him $40 which should cover most of the freight cost.
All it has cost him is some time and a bit of inconvenience.
Personally I would tell him to check his info more thoroughly before making statements like he has to you and use it as a lesson to not lie to people.
Would he have paid you back when you found they didn't fit ??
Not likely!!
Cheers
Ken
i hear the word meelup but noone is ansewering my question - meelup is it where i think it is near dunsborough? if yes - hopefully its a warm sept day where i can hit the beach :) lurve meelup!!
Originally posted by Nizmo
lol @ ken - they aint going haha so thats it til Meelup eh? that is near dunsborough right?
Liz he cant take u to court not much of a case specially with a record like his :)
You have lost me , who's not going?
Have Wanners on the 9th August then Meelup near dunsborough.
The next state m/khana is on June 29th but you will need to join a car club and get a CAMS lic
Cheers
Ken
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
