  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
bloody oath im going to be sad :) hmmm doughnuts - ive been weighing up my cud de sac thinking - i wonder if the neighbours would mind if i practised my circle work - i decided since they let most of their little shits play on the road they probably would. But if theres a motorkhana coming to the grain silo near me soon i wouldnt mind having a go - besides it aint far away to limp home if need be :)
Bam - this is what he said on the PM..... I can't be arsed going to my work email... means disconnecting from here!
yes they will, i was told from a few people they wiil. the caliplers on a gtr and gtst are both four spot. i send them on friday.
(Quote:)
Sneeza wrote on 02-06-2003 01:59 PM:
This is the person who has bought them
(Quote:)
MR33 wrote on 02-06-2003 09:29 PM:
there sold sorry.
(Quote:)
Sneeza wrote on 02-06-2003 09:15 AM:
Hey
Are you sure these will fit an r33 gtst - some one on the forums told me there is no way they will fit
Originally posted by Sneeza
Ken - I know sorry hahaha I saew my mistake....
can he take me to court of I don't accept them?
Liz , don't get so paranoid.
If it really worries you that much , tell him that there has been a misunderstanding and you will send him $40 which should cover most of the freight cost.
All it has cost him is some time and a bit of inconvenience.
Personally I would tell him to check his info more thoroughly before making statements like he has to you and use it as a lesson to not lie to people.
Would he have paid you back when you found they didn't fit ??
Not likely!!
Cheers
Ken
i hear the word meelup but noone is ansewering my question - meelup is it where i think it is near dunsborough? if yes - hopefully its a warm sept day where i can hit the beach :) lurve meelup!!
Originally posted by Nizmo
lol @ ken - they aint going haha so thats it til Meelup eh? that is near dunsborough right?
Liz he cant take u to court not much of a case specially with a record like his :)
You have lost me , who's not going?
Have Wanners on the 9th August then Meelup near dunsborough.
The next state m/khana is on June 29th but you will need to join a car club and get a CAMS lic
Cheers
Ken
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
