  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ok paul :)
Yeah thought thats where it was :) near my old house.
Join Cams - aghhh F*ck that - i'll just ummmm borrow the grain silos pad here in H.W and ummm do after work practice :) What i used to do with the now new Abernethy Rd til they opened it to the public :(
Originally posted by Nizmo
Bam - im 25% irish and my co-ordination sucks!! im also 25% French i would rather practice French Kissing than Irish Dancing :)
French kissing...
I am sooo not going there with this one...
Cheers
Ken
might get the week off in september - take my car down early and stay at my folks place for a while then get a place at meelup with u guys when u get down .... make a proper holiday of it .... depends on my situation at the time i guess but by then i will need a holiday!!
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
