  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
zanda - pauls bitch comment was aimed at me cos i was laughing at him in a gym - its like seeing a polar bear in the bahamas haha
Poor Troy only allowed on in ur lunchbreak when everyone else has gone :) how was ur trip back?
A guy is browsing in a pet shop and sees a parrot sitting on a little perch.
It doesn't have any feet or legs. The guy says aloud: "I wonder what happened to this parrot?"
He parrot says, "I was born this way. I'm a defective parrot."
"Holy shit," the guy replies, "you actually understand everything I said?"
"I got every word," says the parrot. "I happen to be a highly intelligent, thoroughly educated bird."
"Oh yeah!?", the guy asks, "then answer this---how do you hang onto your perch without any feet?"
"Well," the parrot says, "this is very embarrassing but since you asked, I wrap my penis around this wooden bar like a little hook. You can't see it because of my feathers."
"Wow" says the guy, "you really can understand and speak English, can't you?"
"Actually, I speak both Spanish and English and I can converse with reasonable competence on almost any topic: politics, religion,sports,physics, philosophy. I'm especially good at ornithology. You really ought to buy me. I'd be a great companion." the guy looks at the $200 price tag.
"Sorry, but I just can't afford that."
"Pssssssst" says the parrot, "I'm defective, so the truth is, nobody wants me cause I don't have any feet. You can probably get me for $20,just make the guy an offer!"
The guy offers $20 and walks out with the parrot. Weeks go by.The parrot is sensational. He has a great sense of humor, he's interesting, he's a great pal, he understands everything, he sympathizes, and he's insightful. The guy is delighted.
One day the guy comes home from work and the parrot goes "pssssssst"and motions him over with one wing. "I don't know if I should tell you this or not, but it's about your wife and the postman."
"What are you talking about?" asks the guy.
"When the postman delivered the mail today, your wife greeted him at the door in a sheer black nighty and kissed him passionately."
"What???" the guy asks incredulously, "then what happened?"
"Well, then the postman came into the house and lifted up her nighty and began petting her all over" reported the parrot.
"My god!" he exclaims, "then what?"
"Then he lifted up the nighty, got down on his knees and began licking her all over, starting with her breasts and slowly going down...."
"Well???" demands the frantic guy, "then what happened?"
.........."f*cked if I know. I got a hard-on and fell off my perch".
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
