  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken, That's great, can't wait to help him do the engine transplant:D I was at SST tonight, and taking Steve's son to the 2F2F premiere tommorow:D
Steves son ??
And I thought those pedophile innuendos weren't true:D
Cheers
Ken
Originally posted by Kyles
It was really really weird for me..
bwahahha  and mum thinks imm such a good girl..
We all think you are a nice girl
Only Troy knows if your a GOOD girl....
Cheers
Ken
Originally posted by skyzerr33
what was wierd for u sexy?
that ur mum knows a bloke old enough to br your dad that flirts with u?
so paulie she was ur pimp?
Flirt ??
who told you that.
* sshh Kyles , he doesn't know , he is only fishing *
Cheers
Ken:D
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
