  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by angel
Ken if you can't control your breathing don't blame me. If the wife notices, just tell her you have just done a major cardio workout.
Creative accounting whilst intoxicated...
I always heavy breath...
Creative accounting got Alan Bond 2 years:D
Cheers
Ken
Originally posted by GTS-t VSPEC
Ken, I'm not the only one who should be going:p You'll improve your hill climbs with less baggage:p
Tried to give myself a handicap to give the rexes a chance but alas...
they will just have to go faster. hehehe
cheers
ken
Well goodnight everyone. Sweet dreams, keep them clean, and if you can't ensure they involve at least 5 different positions, one form of spread, a swing and a great deal of stamina.
Hmmm well I hope to see YOU in my dreams then
Niite Angel ( or not so by the sounds of it )
hehehe
Cheers
Ken
Haha, I spoke to Steve, he blamed the drivers on the loss:D He said you'd be over 1second quicker in there car:D
Quicker than them or quicker than my time ?
cheers
Ken
