  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
u know Paul Walker has had a Penis Extention -
lol waste of money, they only make the placid organ look thicker r longer not the erect organ haha
you could get nangkans afew ppl have had them they give good grip and last about the same as most high po tyres and are nly 189 fitted at most places
I was out driving this morning in my company car and managed to get a huge flat tyre.... You can just about put your finger in the hole its that big..... ohhhh and changing tyres on the new fords are interesting... The spare is actually under the car and you have to use a wynch ( sp? ) to lower to the ground....
yes i would Troy - but i dont think i would put up with him much after that haha i dont like a guy that uses more hair care products than me haha
Turbos yay. U need a bigger one :cheers:
Chaos thats sweet.
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
