  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
u no like bamie? chicken breast is good for u and yum
mmmm hotdogs yum too :P
Then we had this conisuierre icecream that paul introduced to me - its called english toffee - u gotta taste the stuff its like heaven! :drooling:
hehe bamie tomorrow really i will start - i'll be out for most of the day so the temptation wont be that - i was in a real bad mood today so i went out and bought comfort food ...... i even ignored the rather gorgeous video shops guy ..... i think he likes me ..... but probably after today he's changed his mind!
Soroity Boys ..... someone said it was good - it was ok similar to Van Wilder but Van Wilder was better.
We've got a small video shop - all the good stuff gets takenon friday night so ur just left with shit to choose from on saturday haha - i used to go in there all the time for the scenery ..... i swear that guy thought i probably had no life but was only there for a perv haha
Hey Epoch
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
