  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
Niz takes brownie point off ken :bahaha:
so einstein ..... keeping the auto transmission what is the auto subsitute?
Albert says some type of piggyback AFC which still allows the std computer to be there and control the inputs for the auto computer.
Ken hasn't got a clue...
Cheers
Ken
Originally posted by G0DF4Th3R
Niz - Cheeky!!! i saw that car is scarbs
really cos she onyl did like 50 laps :D
lets put it this way - Liz n i got there at 4pm - she was lapping - we left at 5:30pm and she was just leaving then - or i got the opinion she saw us leaving and decided to harrass us - which she failed miserably at cos she came across a bitch twice as crazy behind the wheel as her :D
was this civic black lowered mugen kit with silly silver decals on it?
if so shes a skank.
ken seeing my boost gauges are both (ie boost gauge and ebc)2psi high can i put a new gauge in and get a more accurate reading considering my boost gauge is a cheapy
Originally posted by caminperth
niz/ken - could use my afc and itc? i'm probably going to head towards power fc me thinks..
Yep , she prolly could.
Trouble with most aftermarket Replacement puters is that it is hard to keep the inputs required for the auto side of things
I doubt wolf would work and Motec or Autronic would be well over 3K
Cheers
Ken
if so shes a skank.
Probable difference was where the takeoffs are compared to what Steve used.
Cheers
Ken
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
