  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
Niz takes brownie point off ken :bahaha:
so einstein ..... keeping the auto transmission what is the auto subsitute?
Albert says some type of piggyback AFC which still allows the std computer to be there and control the inputs for the auto computer.
Ken hasn't got a clue...
Cheers
Ken
Originally posted by G0DF4Th3R
Niz - Cheeky!!! i saw that car is scarbs
really cos she onyl did like 50 laps :D
lets put it this way - Liz n i got there at 4pm - she was lapping - we left at 5:30pm and she was just leaving then - or i got the opinion she saw us leaving and decided to harrass us - which she failed miserably at cos she came across a bitch twice as crazy behind the wheel as her :D
was this civic black lowered mugen kit with silly silver decals on it?
if so shes a skank.
ken seeing my boost gauges are both (ie boost gauge and ebc)2psi high can i put a new gauge in and get a more accurate reading considering my boost gauge is a cheapy
Originally posted by caminperth
niz/ken - could use my afc and itc? i'm probably going to head towards power fc me thinks..
Yep , she prolly could.
Trouble with most aftermarket Replacement puters is that it is hard to keep the inputs required for the auto side of things
I doubt wolf would work and Motec or Autronic would be well over 3K
Cheers
Ken
if so shes a skank.
Probable difference was where the takeoffs are compared to what Steve used.
Cheers
Ken
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
