  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
Niz takes brownie point off ken :bahaha:
so einstein ..... keeping the auto transmission what is the auto subsitute?
Albert says some type of piggyback AFC which still allows the std computer to be there and control the inputs for the auto computer.
Ken hasn't got a clue...
Cheers
Ken
Originally posted by G0DF4Th3R
Niz - Cheeky!!! i saw that car is scarbs
really cos she onyl did like 50 laps :D
lets put it this way - Liz n i got there at 4pm - she was lapping - we left at 5:30pm and she was just leaving then - or i got the opinion she saw us leaving and decided to harrass us - which she failed miserably at cos she came across a bitch twice as crazy behind the wheel as her :D
was this civic black lowered mugen kit with silly silver decals on it?
if so shes a skank.
ken seeing my boost gauges are both (ie boost gauge and ebc)2psi high can i put a new gauge in and get a more accurate reading considering my boost gauge is a cheapy
Originally posted by caminperth
niz/ken - could use my afc and itc? i'm probably going to head towards power fc me thinks..
Yep , she prolly could.
Trouble with most aftermarket Replacement puters is that it is hard to keep the inputs required for the auto side of things
I doubt wolf would work and Motec or Autronic would be well over 3K
Cheers
Ken
if so shes a skank.
Probable difference was where the takeoffs are compared to what Steve used.
Cheers
Ken
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
