  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
*kisses*
Night all
Thanks for a great day Liz :)
Hummph
So it was only Liz that gave you a great day and not my scintillating convo.
Well that's fine . Next time talk to yourself and get drooled over by some other guy then...
* ken goes and sulks*:)
Cheers
Ken
Originally posted by 33Spec2
nah seriously i had work bleh it sucked! otherwise i woulda com down and dynoed the n/a hahahaha:p
Shame , there was a lot of cars ( 31 I have been told by Kelly ).
Lots of people I didn't recognise.
Cheers
Ken
Russ , there was 2 R32 GTR's and I ran 2nd with the ricer.
Gav got 343 ish and I got 322ish at the rear wheels.
EvilR33 ( Brett Hackett ) in his R33 GTR came down but the girl didn't run.
Just like the other girls on here tonight....:)
Cheers
Ken
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
