  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
My fwd is no fun ever. I can put my foot on the brake, other foot fully on the accelerator, and go nowhere, just revving. When brake is released, car still goes nowhere for another 5 secs. Hmm, disappointing, much more fun in the Commodore. Blame my Dad for that comment! He took my damned Skyline. I shall never be over it.
Gotta go anyway, have work to do,
cheerio!
Originally posted by Nizmo
Bam - DO NOT TOUCH HICAS!!
u need a special lock kit to disable it - u go pulling plugs out willy nilly and ur car will be unable to drive - go ask strich9 he did it. SPECIAL LOCK KIT NEEDED!!
That is correct.
Thanks for pointing that out Niz, I almost forgot, well, tried to anyway....I pulled out the HICAS computer located in the boot under the parcel shelf. It disabled power steering completely, and was a BITCH to drive.. hehehe. Don't try it.
I _DIDN'T_ However, try to pull out the three little plugs on the HICAS actuators under the car (near the diff) to disable it. Hmm.. That get's me thinkin....
*It's time to watch Kym do something stupid and be the guinea pig again!!*
off i trot....
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
