  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
My fwd is no fun ever. I can put my foot on the brake, other foot fully on the accelerator, and go nowhere, just revving. When brake is released, car still goes nowhere for another 5 secs. Hmm, disappointing, much more fun in the Commodore. Blame my Dad for that comment! He took my damned Skyline. I shall never be over it.
Gotta go anyway, have work to do,
cheerio!
Originally posted by Nizmo
Bam - DO NOT TOUCH HICAS!!
u need a special lock kit to disable it - u go pulling plugs out willy nilly and ur car will be unable to drive - go ask strich9 he did it. SPECIAL LOCK KIT NEEDED!!
That is correct.
Thanks for pointing that out Niz, I almost forgot, well, tried to anyway....I pulled out the HICAS computer located in the boot under the parcel shelf. It disabled power steering completely, and was a BITCH to drive.. hehehe. Don't try it.
I _DIDN'T_ However, try to pull out the three little plugs on the HICAS actuators under the car (near the diff) to disable it. Hmm.. That get's me thinkin....
*It's time to watch Kym do something stupid and be the guinea pig again!!*
off i trot....
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
