  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
hey Bam :) yeah im lurking - catching up on the goss :)
haha Kym another warning: Leave your poor car alone!! :D I quite often see u driving thru West Perth on way to work in morning but u dun notice me :(
*sigh* Nah, in a world of my own when I'm driving I am...
.. what's the world coming to when ya don't notice a blonde driving a line anymore!
Dam work has me busy as hell, I don't even get time to write emails! *sigh*
Next time ya see me toot like hell and I might see ya!
