  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
i would just like to say the bigger the wing the gayer it is cos it looks like u boys are trying to compensate for something.
Ahhhh the thing su can safely saywhen pwpf aint here ;)
Ahhheeeemmmm young Lauren ( that's the , I'm in trouble tone )
what about my ricer ???
That is NOT a gay wing
It's a Big Arsed Gay wing.
Heheheheheeheheheheheheehehe
Cheers
Ken
My ride should look choice it practically looks like a GTR ;) but unfortunately thats where the similarites between the two end :P
Well Sweet Dreams
Sweet dreams, you aren't going to bed YET ??
Are you ??
Cheers
Ken
Night Niz...
Troy: My course today was ok..... Today's was a 1 day course so it is finished.... I now have a 4 Day course to finish the week off.... I like these trips to Melbourne as the training is quite relaxing, it's almost like a holiday ;)
