yeah well i thought i was driving sensible - i dont realise til shes in the car how much over the speed limit i do "being sensible"
i am a shocker ........ probably loose my license one day :) but i cant help myself!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
too cold to wear something sexy - for me at the moment its jeans and a jumper haha.
i used to get discounts cos i worked at toyota around there - but i dont anymore :) anyway see how it goes. Save some $$$ cos i jus tpaid $800 off my credit card sooooo things are a bit tight in the old bank account - plus i havent worked a full week in a while!
heeh its the champagne - my glass is now empty and i cant go back for more cos my grandparents already thing we are a family of alcos! besides i better sober up for cruzzzz - just at that nice floating feeling at the moment!
Paul - my brakes used to be really and i mean REALLY good!
hehe Liz msg'd me she just saw that S-l-u-t (her words not mine) Che3ky in Maddington - the chick in the Honda that took me on last weekend - god wish i was there .... haha i wanna make her look bad again!
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
