  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha man that chick pissed me right off - she stalked me to begin with - she deserved the humilation she got!!
i had another honda take me on the other day ..... guy this time .... it was funny because his car was really getting a hammering and mine was just beating it so easily without trying
PS - the boost has made a difference! haha the std guage was pretty lazily moving before - now it moves pretty fast - as soon as u shove ya foot on the accelarator the guage goes up almos tin tim to the tacho - haha rather funny!
NEWSFLASH: my cat has caught a mouse haha
aww paul - haha im sure u'll manage - have fun in scotland if we dont talk for a while
Phil - It takes u 3 hours to make urself smell nice? thats a worry!! C U tonight!
Hey Bam *hugs*
Paul - Zenah is a good little mouse catcha! trust me she may look fat n lazy but shes quicker than the white fluffball! Ive got so many scratches on my hand to prove that! she's a mini tiger - shouldve called her Hobbes hehe
i know u did - but i think we shouldve done a second run on that one - its definately made a noticeable difference - just wasnt comfortable - we shouldve done it on a less built up area like abernethy rd :)
