  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
no.
Its on the left side of my tummy.   Dam doc needs a kick up the butt for giving it to me but :) Cant even laugh with out it hurting.. sneezing is the worst.
Hi again micko :D
tummy, geezus , how big is Troy ??
Ahh , don't bother , I REALLY don't need to know:D
Cheers
Ken
Originally posted by Micko
How did Rallymax go today Ken?
Did you show those lads how a car should be driven?
I don't drive , I instruct from the passenger seat or the glovebox.
Rob Herridge does the scary stuff at the end
Cheers
Ken
Ken - we still cant work out what is going wrong with it...
We removed the immobiliser, put in a new stereo & when I left Danny was busy tidying up the spider's web under the dash.
Still have power problems when he goes around a corner or over bumps...the car loses all power for a short time, then farts & carries on...got us both stuffed:confused:
Dont call him big boy for nothing hahahahahahhahahahhahahahaha
Yes but virginal Kyles , how would you know big if there is nothing to compare him to.
Which is why girls can't measure distance , cos they have been told that 2 is actually 12inches
hehehe
Cheers
ken
Tahts weird.
I can assure you that it NEVER did that b4.
Cheers
Ken
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
