  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
does anyone know anything about lillies????? My mum bought me one that grows... Problem is.. i do NOT have a green thumb (that would look weird) And i dont know if i should water it everday ... every second day.. I dont want to kill it .. it looks nice :) Should i re plant it in a bigger pot? The pots a bit little? herm.. Heven help me when i get a garden! hahahhahahha..
I bought a some hurbs that grow.. it was dill.. I managed to kill it in 3 days.. not bad huh!!?? LOL
