I have loads of male friends.. some times i prefre them to female friends. I have more bloke mates than girl friends. Girls can get so bitchy and fights last forever.. blokes get over it and done with it.. thats why they make good mates..
My problem with girls is that some times i just cant stand some of them.. I think its me and my personaity. I would rather go out on a moter bike for the day than sit at home having facials with my best friend (which isnt like her anyways.. ) but that is rare in a girl. I think thats why i dont have many female friends. I also think im a bit more mature than most girls my age. The girls i sit with at uni are a bunch of imature twits and drive me nuts with the conversations we have... the other choice is a bunch of old buggers who just talk about their hubbies and stuff.. I just cant fit in anywhere lol. oh well.. im there to learn (geek!!)
I was the same at school. I would be on the oval playing football with the blokes than sitting in the corradores with the girls giggeling about stupid stuff.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
suttle hint to what honey?????
I think guys just have to deal with the sexy women that they are with are going to have male friends and male friends that want to get in their pants.. Doesnt matter.. aslong that the trust is there that the one you love is the one and only :) Tatoo it to his forhead liz. Why dont you bring him along one time and then he can see what goes on. You may have to get ken to behave himself though lol
I have been with people that think that they are so crash hot they think no girl would ever stray from them.. (was he wrong) cos i strayed to Troy hehehehehe
and ive been with guys that think im with every other guy on the planet... Well that may have been true but i wasnt interested in a relationship with anyone at that stage and they where just back up.
Dont stress troy your not back up.. Ive settled down now :D hehe..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
