  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
After research into Freddos Family Tree I have discovered that Freddo was a result of an affair between the High Class Blue Rollerball Pen ..... one of the more exclusive pens in the Stationary Kingdom and the Green Highlighter who was quite lowly.
One morning not so long ago - i arrived at work to discover there had been a pen napping assuming they were already in slavery at a co-workers home for their grubby 5 yr old to play with ..... i made my way to the Stationary cupboard to adopt some more.
