  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i put freddo away today ;) he needs a res ti think the highlighter worn him out last night :P .... i'll get back to him tommorrow if i have time :)
Troy - already stooped to his level enough but actually bickering - i can actually only bite my tongue for so long. As for the other Lauren she only wants to get in on it cos ive heard she can be quite bitchy to other females driving performance cars ..... besides i dont think its worth starting to argue with anyone with pink piping in their car anyway :D ok thats my little growl sess - shall leave the topic alone now.
Hey Bam - how u doing sunshine?
poor freddo
and you'll heaps bigger than her in all the good ways height, bust etc, u can take her, we'll remember to bring the camera
Troy im not like that - its just she had no reason to enter that convo and ive already been "warned" about her bitchiness ..... now shes trying to stick her claws into me and i will take it for so long then i will turn around and bite back so hard she wont know what hit her.
Poor freddo? why .... he was getting some sweet loving from the highlighter :uh-huh:
On site? damn! oh well tell him the good news when he returns.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
