  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha Troy if u read back a page - u'll see he is suspected of killing the highlighter ...... an investigation is being carried out by Mr. Rubba the Detective Eraser around here ....... if enough evidence is carried out Judge Ruler will carry out the court case.
I suspect he was drunk on his own power at the time
Bam - body Shop body butter - its the most divine smelling stuff on earth ...... i can put it on and still smell it on my skin two days and four showers after!! i cant leave the lid off it cos my cat tries to eat it!
hey skyzer,
Ive seen that dash before. On taka I think.
Its BULLSHIT expensive. Maybe made by Ideal or something?
It's like a defi-system thingy, but it has whatever gauge you want already hooked up. you just cycle through.
also has digital speed etc.
I will try and find it for ya.
thats the thing - why spend money on guages when u have something like that? in the end its worth the money - depends how bullshit expensive is expensive - about 1.5K? my guess
CC - i can spell out the characters - but as for translating them no i havent had much experience. one day i'll go back and learning.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
