  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
haha ken - i dont think the wife would apreciate four in the bed :D
Wife , what wife ?
Ohhhh , you mean THAT wife.
oops yea , forgot about that.
Damn alschiemers
Where were we again ??:P
Cheers
Ken
Originally posted by 33Spec2
hey ken liz niz
dont know yet hav 2 wait till 2mora fingers crossed i may come on the cruise!
I was gonna but a leaking water pump put paid to that .
Can't get a new one till Tuesday ( ex east Melbourne ).
Bugger.
Cheers
Ken
thanks Ken :grouphug: back at ya
well at this shameful time i is going to bed .... head not thinking to well even for whoring :P
Good night all
Nite Niz.
Hope you are ok and over the Andrew thing.
Go and get pissed tomorrow night and have a shooter or two for me.
Cheers
Ken
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
