  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yep I am working.... I am looking after things here at QV1 .... people keep wanting to do things so I have to keep organising stuff.... but I am always near by! :)
Hmmmm Chinese..... You get lots of different nationalities to learn about :D
