  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah - I will negative gear my house and I claim back all my tax paid in singas if I work for more that 168 days in a financial year - out of australia. I can also claim back on flight per year to "inspect" my house. There is heaps of things... plus I hate my current employer and I want to experience work OUTSIDE of gay arse perth!
hmm..seems the exact opposite for me...that's y i'm here. things and places go a little pear-shaped when you've been around in the same place for more than 20yrs....
my money!! for phuck sake! They are coming down to telling me what i will and will not spend my money on ;)
i earn it i'll phucking spend it how i please ...... plus they are constantly grumpy and ordering me around like one of their employees *gripe, gripe, gripe*
When i first came home they were cool and let me live my own life - but they are starting to take over again and its pissing me off.
If i didnt need to save for Europe next year i would move out.
Liz - i did that ............... it didnt work to well haha but as soon as i got back off holidays the new car manager was on the phone to me ...... it was stupid them letting the only person that knew how to run that department walk and they needed me back - n stupid me went back for a while ;)
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
