  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
oooo kinda a sleighty on an R33 hmmm i dunno ....... ive seen people kinda put some tape shit on their lights across the top to make them look more squarer like the R34 .... aidwin has done it me thinks .... but thats it.
hehe i already got a slurry nick - Lolly Longlegs .... i can see the heading now ... .but i wont repeat it haha we have visitors and its dirtee!
Ever seen those personal ads ....... lonely housewife .... husband is away .... needs robust male.
Phucking cracks me up
nah...this seems like the real deal...i thought it was just another R34 when i saw the rear shot....it's an R33!:uh-huh: the headlamps and everything of the 34.....
