  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
it goes by the amount of posts u have :( if u go into ur profile .... u'll see how many posts u have
yeah a sticker of that would look sweet on the back of the car ..... but i still want a picture of the drift monkey ( well it looks more like a cat if u ask me) but i cant seem to find one!!
ooooh im coming up to 10,000 posts.
im urrently on 61 a day it used to be 65 tho - but i dont get on the net as much at night now and i used to post more through the day cos paul was here to talk too soooo til u came in there was noone to "whore" with :(
haha thats ok i dont know much about it myself ..... u see it on drift cars that come from japan - its a little sticker of this cat/monkey that looks like a two yr old drew it - but its still cool ..... i saw a car in HPI with one on and ever since wantedone - when i was looking for my Skyline i saw a couple of silvias in a yard with them on ...... maybe for my birthday next year someone will buy me one .... or xmas haha
he's just a cool little dude - cant find pictures of him on the net either :(
haha i have to get new toner for my bosses printer which requires me to get on my hands n knees and get under his desk to see what printer he has ..... he wasnt in the room at the time - but even though - it looks mighty suspious hahaha
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
